Date/Time: Sun, 28 Apr 2024 11:36:22 +0000
market stats - alternative indicators
View Count: 671
[2020-01-14 16:37:43] |
Chad - Posts: 231 |
Hi SCE, got a question pertaining to data out of the main line of focus - for example, stats like EIA Natural Gas Storage Levels - it appears there are futures on ICE for them: https://www.theice.com/products/37042676/EIA-End-of-Storage-Index Likewise for data from US Fed, easiest to get from the FRED database, say Repo operations... are these something that you'd consider adding as market stats? Since the first example is an actual future, I assume it would be added as such, and not a Market Stat, but it's relatively-illiquid, so I wouldn't figure anyone would want to actually trade it, just use as a reference. |
[2020-01-14 18:51:56] |
Well we certainly can add any ICE futures symbols that we do not already have listed. We will look into the one mentioned.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-14 18:52:03
[2020-01-14 18:55:13] |
We did have a look for this: https://www.theice.com/products/37042676/EIA-End-of-Storage-Index But do not see it on the ICE data feed we get from Barchart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-14 18:57:08] |
Chad - Posts: 231 |
Okay; I'm currently scraping this data, so like other 'alternative' stats, I can just write to basic text per your format requirements for loading external time series, and go from there...figured I'd ask about official support, though.
