Date/Time: Fri, 03 May 2024 13:52:58 +0000
Using Sierra Chart data with Ninjatrader brokerage
View Count: 3262
[2020-01-12 22:58:12] |
User310898 - Posts: 35 |
Hi, as I understand it as it stands there is no way to connect a live Ninjatrader brokerage account (Dorman) to Sierra Chart when using Sierra Chart real time data. I have had discussions with you about setting up Sierra Chart data feed for which you were very helpful. however I just noticed the section "Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees". I am a non-professional eligible for the reduced CME fees however if I cannot connect my Ninajtrader brokerage account to Sierra Chart for the check mentioned in "Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees" how will that work? Does it essentially mean because of this issue of not being able to connect the NT brokerage account I cannot qualify for CME non-pro fees using sierra chart data? Is there no way round this if this is the case, as far as I am aware DTN IQ Feed just need confirmation of non-pro eligibility from the broker and they are good to go without this once a month live connection. Anyway any clarity appreciated. Thanks! |
[2020-01-12 23:40:26] |
There are two solutions. Is your ninja trader account using CQG or Rithmic? If so Sierra Chart can connect to those systems to verify the account. There is also this new solution offered which is the recommended solution: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-12 23:40:49
[2020-01-12 23:57:28] |
Thanks. OK so I get the $100 AMP option. Yes the NT account is using CQG (Continuum). So if I do not want to open another $100 account you are saying you can do a verification given I use CQG for routing. |
[2020-01-13 00:03:36] |
Yes but ninja trader would have to allow Sierra Chart to be able to connect to your CQG account. We really do not like this type of solution though. And it will also cost you $10 a month more. Longer term it is cheapest and also cleanest to use the $100 option with AMP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-13 11:14:09] |
NotIll - Posts: 118 |
Could I please know what this 100$ option with AMP is?
[2020-01-13 11:33:09] |
@ NotIll it is here bud: Easy Solution to CME Funded Trading Account Requirement |
[2020-01-13 11:57:54] |
"Yes but ninja trader would have to allow Sierra Chart to be able to connect to your CQG account. We really do not like this type of solution though. And it will also cost you $10 a month more. Longer term it is cheapest and also cleanest to use the $100 option with AMP." OK I will open the AMP account, if I have any problems I will let you know. Otherwise thanks as always for the top quality support. |
[2020-01-13 14:12:51] |
@User310898 appreciated |
[2020-01-22 13:58:49] |
hi have you seen the messages I have sent in the account control panel? thanks
[2020-01-23 06:27:40] |
Yes and the process is now complete regarding the TT account assignment.
[2020-01-23 07:41:41] |
Excellent thanks works seamlessly great job guys.
