Date/Time: Sun, 05 May 2024 12:46:43 +0000
Difference in daily chart and intraday one chart - CEI
View Count: 1229
[2020-01-10 20:38:24] |
Kinobe - Posts: 86 |
hi I wondering why I can not get the same chart in daily chart and intraday chart with one day for ticker CEI - see attached picture. I did Delete and download data for each chart. but both chart are pretty differents... what should I set up in order to get same chart in daily and one day intraday chart. thank you |
Daily_CEI.jpg / V - Attached On 2020-01-10 20:35:45 UTC - Size: 218.97 KB - 285 views intraday_CEI_1Day.jpg / V - Attached On 2020-01-10 20:35:52 UTC - Size: 230.21 KB - 286 views |
[2020-01-11 05:31:47] |
What is the difference you are seeing?
[2020-01-12 17:53:15] |
see pictures attached to see the difference since the 29-10-2019
Daily_CEI.jpg / V - Attached On 2020-01-12 17:51:35 UTC - Size: 423.37 KB - 254 views intraday_CEI_1Day.jpg / V - Attached On 2020-01-12 17:51:43 UTC - Size: 452.01 KB - 273 views |
[2020-01-13 18:52:20] |
It looks like there is an adjustment required for a stock split. We are checking on this later today.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-13 21:47:51
[2020-01-21 01:22:16] |
did you have time to check?
[2020-01-21 23:16:35] |
The stock split has been applied to the historical Intraday data. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-21 23:16:41
[2020-01-22 02:46:32] |
is there way to know when a stock splits with sierrachart??
[2020-01-22 08:35:54] |
No, other than observing a significant price change.
