Date/Time: Sun, 19 May 2024 19:22:43 +0000
AWL->Set Charts to Symbols crashes Sierra
View Count: 808
[2019-12-27 21:42:19] |
Chad - Posts: 231 |
Hi SCE, just a notice: I was attempting to set a few Chart windows in v2017 to symbols that were loaded first to a new Quote Board window, then I clicked the 'Symbols' option in its menu bar, which opened a new Watch List window (titled 'Symbol List'). Then I clicked its Symbols menu option and Set Charts to Symbols...SC crashed. I'm running 64-bit Win7; screenshot of SC when it happened, and the error details from Windows are attached. |
crash_window.png / V - Attached On 2019-12-27 21:41:47 UTC - Size: 68.36 KB - 249 views problem_details.txt - Attached On 2019-12-27 21:41:55 UTC - Size: 821 B - 254 views Attachment Deleted. |
[2019-12-27 22:48:52] |
We will fix this. But also that command cannot be used on a Quote Board. We will make sure it is disabled.
