Date/Time: Sun, 19 May 2024 13:08:30 +0000
64 bit exe loads 32 bit program
View Count: 535
[2019-12-26 19:18:27] |
User803872 - Posts: 14 |
In linux (ubuntu) I get the behaviour described in the title. Upon checking the version in 'about' it confirms 32 bit. Please could you advise why this is happening. Many thanks |
[2019-12-26 19:21:08] |
One thing to do is to go to the Sierra Chart installation folder and delete the SierraChart.exe file. Keep the SierraChart_64.exe file.
[2019-12-26 19:31:23] |
Cavalry3162 - Posts: 523 |
just an fyi mine loads up as 64 bits correctly fwiw, my SierraChart.desktop file: [Desktop Entry]
Name=Sierra Chart_64 Exec=env WINEPREFIX="/home/andreas/.local/share/wineprefixes/Sierrachart" /usr/bin/wine C:\\\\SierraChart\\\\SierraChart_64.exe Type=Application StartupNotify=true Comment=Sierra Chart_64 Icon=C8FB_SierraChart_64.0 StartupWMClass=sierrachart_64.exe you obviously have to alter the WINEPREFIX path to your needs.. |
