Date/Time: Sun, 19 May 2024 14:54:46 +0000
The scale of the graph has a bad adjustment.
View Count: 561
[2019-12-26 08:38:51] |
Hopeman - Posts: 156 |
The scale of the graph has a bad adjustment. Using the Chart Drawins copi tool of chart settings, advance settings 2 ,the lines drawn that are reflected in a second graph have a poor fit try to adjust the reload graph but it is not the solution, please if someone can help me, I leave a couple of photos of the same instrument in one photo the bars support, in the second photo the bars have already exceeded the line when they should be below, thank you very much |
Private File Attachment Deleted. Private File |
[2019-12-26 21:43:48] |
Your Sierra Chart account is expired. For support you need to log into your current account and you can do that through Help >> Support Board. For help with the issue, refer to: Lines/Rays or Other Chart Drawings Move After Drawing Them: Chart Drawings Are Misaligned After Changing the Period / Timeframe Per Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-26 21:44:01
