Date/Time: Sun, 19 May 2024 11:05:10 +0000
volume by price only display the latest day
View Count: 558
[2019-12-25 15:38:23] |
User509345 - Posts: 44 |
pic 1 is my option.pic 2 is my goal,display everyday vp
volume-graph-period-type.png / V - Attached On 2019-12-25 15:36:21 UTC - Size: 93.83 KB - 266 views Snipaste_2019-12-25_23-31-53.png / V - Attached On 2019-12-25 15:36:52 UTC - Size: 57.28 KB - 238 views |
[2019-12-26 21:42:40] |
Change the Volume Graph Period Type to one of the Multiple options. Most likely, you would be wanting the one for Multiple Profiles based on Fixed Time. Refer to the options here: Volume By Price Study: Volume Graph Period Type Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-27 02:25:36] |
Thanks.It's ok now.
