Date/Time: Sun, 19 May 2024 13:24:29 +0000
Automatic stocks buying on bar breakout
View Count: 531
[2019-12-24 22:15:29] |
User277632 - Posts: 8 |
Hi, Let me know please if it is possible to do this: Create/add a list of stocks which would be automatically bought on 15 min bar breakout (first 15 min bar from market open at 9:30). Thank you. |
[2019-12-26 15:48:26] |
John - SC Support - Posts: 31708 |
Yes but it has to be custom programmed using ACSIL. Refer to the following for getting started with ACSIL: Advanced Custom Study Interface and Language (ACSIL) And here is the documentation for trading using ACSIL: Automated Trading From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
