Date/Time: Sun, 19 May 2024 14:29:51 +0000
Volume Profile (Composite)
View Count: 2390
[2019-12-24 13:07:48] |
pistenraudi - Posts: 1 |
I try to set the same composite volume profile as I used in NinjaTrader, but without success. 1. I find no solution to fix the profile on the left or right side (no move if I shift the chart on the right or left side). 2. I can’t adjust the ticks per volume bar on 1 tick (it chance automatically on 5 ticks) 3. I don’t want to load 15 Years back the chart. 4. Is there any possibility of auto LVN and POC drawn with a sensitive adjustment? Could you tell me how I can set the Composite correct, to get the same composite? |
VbP from start date- time to end_Chart 2.jpg / V - Attached On 2019-12-24 13:04:08 UTC - Size: 467.11 KB - 439 views VbP one Period at End of Fix_Chart 1.jpg / V - Attached On 2019-12-24 13:04:16 UTC - Size: 450.99 KB - 398 views NT_CL_Composite VP.jpg / V - Attached On 2019-12-24 13:04:23 UTC - Size: 568.46 KB - 480 views |
[2019-12-26 15:45:13] |
John - SC Support - Posts: 31721 |
1. You can fix the profile to the Right Side. Refer to the following: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart 2. Refer to the following for why you are unable to change the Ticks per Volume Bar: Volume By Price Study: Ticks Per Volume Bar 3. Not sure what this question is about. You only need to load however much data you need. Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad 4. If, by LVN, you are referring to a "Low Volume Node", these are called Valleys in Sierra Chart. Yes, you can display Peaks and Valleys based on the surrounding information. Refer to the following: Volume By Price Study: Draw Peaks and Valleys The POC is not controllable, it is automatically determined from the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
