Date/Time: Tue, 04 Feb 2025 02:01:49 +0000
Volume by price bars skewed under certain conditions
View Count: 799
[2019-12-20 16:33:39] |
User258363 - Posts: 18 |
Hello, I'm seeing an issue with the volume by price indicator where the bar would be extremely skewed (very long width wise) and then jump back down to regular size once more volume hits into it. See the screenshot and the chartbook. In the chartbook, if you replay to 10:13 central time today (12/20/2019) you can see it in action. |
SupportChartBook.Cht - Attached On 2019-12-20 16:31:18 UTC - Size: 94.16 KB - 355 views |
[2019-12-20 18:21:47] |
Your Sierra Chart account is expired. We need you to post from your active account by using Help >>Support Board. When that is done make a posting here to let us know.
[2019-12-20 18:38:08] |
User379717 - Posts: 10 |
Hello. I'm logged into my AMP account now. Thanks for letting me know.
[2019-12-21 04:40:39] |
There is nothing wrong with the display of the VbP. What you are seeing is due to having the Volume Bar Calculation Method set to Diagonal Ask Volume - Bid Volume, and then having the Bid Volume and Ask Volume Coloring Method set to Difference of Bid and Ask Volume Coloring. This means that there is a large difference between Bid and Ask at that price level, but this is not necessarily true of the Diagonal Calculation. Just change the Bid Volume and Ask Volume Coloring Method to something that reflects what you are looking for. Refer to the following: Volume By Price Study: Bid Volume and Ask Volume Coloring Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
