Date/Time: Thu, 02 May 2024 21:21:05 +0000
Question: Using Market Depth recorded data files with another trade/data service
View Count: 446
[2019-12-15 16:58:26] |
ticinotrader - Posts: 378 |
Dear Support, I am using multiple data/trade service connections in separate SC instances. I am recording the market depth data while being connected to your Real Time datafeed but would like to use them for replay in other instance that is connected to a different feed (IB). The symbols are different (ZNH20 vs ZN-202003-ECBOT) Can you please confirm that the depth data files can be used with another instance, or if not, is there a fix to 'translate' the SC symbol format depth files to another connection? Thank you. |
[2019-12-16 05:30:56] |
You can certainly use the data as long as you rename the file but the internal price format could be different. But most likely the same. Certainly for bonds it would be the same.
