Date/Time: Tue, 07 May 2024 15:50:14 +0000
[Programming Help] - Reverse with single order
View Count: 516
[2019-12-14 15:13:01] |
User819680 - Posts: 7 |
With a spreadsheet systems, is it possible to reverse position with a single order in the opposite direction, as opposed to placing a closing order and then a subsequent opening order?
[2019-12-14 15:23:43] |
Refer to: Automated Trading Management: SupportReversals Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
