Date/Time: Sun, 28 Apr 2024 00:41:49 +0000
Switching from affiliate to SC direct
View Count: 660
[2019-12-13 19:49:45] |
User600284 - Posts: 9 |
Hi, I have one question before I ask you to switch my account from AMP affiliate to SC direct. I'm trying to accomplish below and if it's doable please help me switch. I still need to trade futures with AMP (so I'll keep the account there) with their data feed for futures. I also need access to stock charts so I established account with Interactive Broker for their stock snapshot data feed. I'll only need to use volume profile and TPO in service package 5 for stocks. So can I open a new instance or a new copy aside from the main instances for futures to chart stocks with IB data feed? IF this is possible please help me switch to SC direct account. Thank you. |
[2019-12-14 05:24:07] |
Yes you will definitely need a direct Sierra Chart account: Direct Sierra Chart Account And you do need a separate installation of Sierra Chart for Interactive Brokers: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
