Date/Time: Tue, 07 May 2024 10:11:56 +0000
SC data cost
View Count: 742
[2019-12-13 19:02:29] |
Dennis B. - Posts: 263 |
I currently have 3 instances of SC on one computer, using IQ feed. I have service package 3. What would be the total cost to go to your data feed ? Just using charting not the trading platform.
[2019-12-13 19:16:13] |
SC Support - Posts: 1797 |
Hi there, What exchanges are you focused on? The CME Group Exchanges only (CME, COMEX, NYMEX, and CBOT)?
[2019-12-13 19:35:36] |
I just trade the ES e-mini, that's the CME Exchange nothing else. As far as I know.
[2019-12-13 19:52:58] |
You can have the Denali Exchange Data Feed on 2 systems simultaneously with no symbol limits for $25 / month (not including the exchange fee to the CME). How does that compare to DTN IQ Feed? Denali Exchange Data Feed |
[2019-12-13 20:14:20] |
First, I don't see any Denali feed on your data feed selections.Why can't I use SC data ? Also, I need 3 feeds for 3 instances of SC not just 2. IQ feed=$ 121. per month. Totally confused by your response..
[2019-12-13 20:44:33] |
Can we ask if you are a Professional under CME Rules? See below from the CME definition of a Non-professional "The Non-Professional Subscriber's Access to Information must only: h. be via a maximum of two trading terminals per Distributor, permissioned for Real-Time Information and capable of routing orders to the CME Globex Platform (an "Order Routing Device")." As things stand, speaking about the CME only, our Non-Professional clients are limited to using 2 systems simultaneously, for that we charge $25 + the CME exchange fee. Our best CME focused feed is called the Denali Exchange Data Feed. Denali Exchange Data Feed Are some of your questions answered here? Date Time Of Last Edit: 2019-12-13 20:44:53
[2019-12-13 23:11:17] |
You only need one data feed since all your instances are on the same computer. You will use the DTC server to share the data and that is what you need to do: Using DTC Server for Data and Trading in Another Sierra Chart Instance You do not want to have three simultaneous connections. That is inefficient and we do not recommend that. The new Denali Data feed is the replacement data feed for CME group data as compared to the SC Exchange Data Feed. In regards to post #6, there is a misunderstanding between computer systems and instances on the same computer. This user just has multiple instances which only require one feed. Set up instructions are here: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-13 23:14:00
