Date/Time: Sat, 27 Apr 2024 11:33:01 +0000
Trade Configuration stuck
View Count: 571
[2019-12-13 16:18:01] |
User688389 - Posts: 2 |
I haven't realized until recently that whatever trading windows configuration I set, it always stuck to one setting. For example initially I have configurations that allow me to set 24/8 (24 pip target, 8 pip stop loss), and 40/7 (40 pip target, 8 pip stop loss). But now whatever configuration I choose, it always put the order as 24/8 Please help |
[2019-12-13 23:34:09] |
Refer to this section: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Another possibility: It sounds like the first configuration was written to the second configuration by accident. Change the second configuration to what you want it to be, and be sure to save it again, then see if what happens when you change between the configurations. Refer to the information here for how to save a configuration: Basic Trading and the Trade Window: Saving Trade Window Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-13 23:35:09
