Date/Time: Tue, 07 May 2024 05:53:18 +0000
Manual Price Line Drawing/Input
View Count: 764
[2019-12-13 14:42:07] |
User9415867 - Posts: 38 |
Due to scaling, I notice that the location of my price lines can move slightly. Is there a way to draw a line by inputting the exact candlestick high/low to connect to another candlestick high/low via manual input instead of drawing?
[2019-12-13 23:31:55] |
There is no way to enter the values up front for a drawing, but you can always modify the Anchor points after you have finished the drawing. Refer to the following documentation: Chart Drawing Tools: Chart Drawing Properties Refer to Anchors in the following: Chart Drawing Tools: Common Tool Configuration Settings and Chart Drawing Properties Also, you can use the Automatic Snapping to connect to the High, Low, Open, or Close of a bar when creating or modifying a drawing. Refer to the following: Chart Drawing Tools: Automatic Snapping of Chart Drawing Ends to Open, High, Low or Close Bar Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
