Date/Time: Sun, 19 May 2024 00:28:36 +0000
Trade Orders Window Background Color
View Count: 1590
[2019-12-13 13:27:03] |
User568539 - Posts: 18 |
From SC Version 2007 and older, my Trade Orders Window had the same identical Light Gray colored background as my Account Balances Window, and my Trade Positions Window, and also my trading charts. From SC Version 2008 and newer, the Trade Orders Window has a black background. Why did this happen and how do I get a Trade Windows background color that is identical to the other windows like it used to be? Thank you.
[2019-12-13 15:51:31] |
Ackin - Posts: 1865 |
Sierra Chart Engineering In version 2020 if the foreground and background colors are the same for the Trade Orders Window they are now reset to default. So the easiest thing to do is just update to version 2020. The relevant color settings are documented here: https://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#FontAndColors The settings you show in the Graphics Settings window are not the right ones. Trade Orders Window black after upgrading |
[2019-12-13 16:40:09] |
Yes here is the relevant documentation to follow for all of the color settings for the Trade Orders Window: https://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#FontAndColors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
