Date/Time: Mon, 06 May 2024 12:14:54 +0000
Study: Add Additional Symbol lost Symbol after start Translate Symbols
View Count: 827
[2019-12-13 10:45:31] |
TedMar - Posts: 189 |
Study: "Add Additional Symbol" lost Symbol after start "Translate Symbols to Current Service" process ..
[2019-12-13 22:52:24] |
This will be corrected in the next release coming out today. The current implementation does not even work properly as it is just changing the symbol to the same symbol of the chart if it can be translated. Otherwise, it is just clearing it. This is wrong.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-13 22:52:49
