Date/Time: Tue, 07 May 2024 02:57:34 +0000
Rithmic api log
View Count: 619
[2019-12-13 09:01:16] |
User179926 - Posts: 2 |
Having connection issues using Rithmic (paper trading). How/where can the Rithmic api log be generated. The message log that is generated is of no help to them.
[2019-12-13 18:28:38] |
The Rithmic log file should be in the Sierra Chart installation folder in the Rim subfolder.
