Date/Time: Thu, 02 May 2024 21:33:30 +0000
ROLL issue
View Count: 556
[2019-12-13 07:44:23] |
arruga - Posts: 249 |
Hi It seems the roll for M6E is having a problem http://www.sierrachart.com/image.php?Image=1576222952276.png Delete & download & recalculate are not working Please advise thank |
[2019-12-13 14:05:57] |
Is this a back adjusted continuous contract chart? If so, the remaining gap is based upon the difference of the daily open prices on the rollover date. So the calculation is correct. To do a further adjustment, refer to: Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-13 14:06:21
