Date/Time: Sat, 04 May 2024 05:59:56 +0000
Data Pricing
View Count: 674
[2019-12-13 01:19:19] |
User479525 - Posts: 21 |
What is the difference between Denali and Sierra data feeds? Which is better?
[2019-12-13 01:24:22] |
SC Support - Posts: 1797 |
If your focus is within the CME Group Exchanges you should be using the Denali Exchange Data. Denali Exchange Data Feed Main things to your benefit with Denali -- lower latency -- currently no symbol limits -- can be used on 2 systems simultaneously |
[2019-12-13 01:30:18] |
I currently use Transact Futures as broker and data provider. How can I use Denali and still have Transact broker?
[2019-12-13 17:06:39] |
Yes this is fully supported. But understand you would pay exchange fees twice. There is nothing special to do. Also you will want to use the Denali data feed: Denali Exchange Data Feed Let us know if you want to proceed and we will help you. Also you will need to use the Denali data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-13 17:11:47
