Date/Time: Sun, 19 May 2024 20:16:41 +0000
Extract data from spreadsheet study .scss file
View Count: 966
[2019-12-12 15:40:23] |
User796313 - Posts: 6 |
Hi, I have been able to successfully extract data from the .scid file using the intraday format give here. Intraday Data File Format Now I want to extract data from a .scss file. Can you please let me know the header size and the byte formats/sizes of the data that is to be stored in this file. If you have any detailed documentation like that of the IntradayDataFileFormat it would be of great help. I understand from your previous posts that .scss is a customized Sierra specific file and it is not easy to read. I Just want to omit the headers and read only the first line containing the data in the spreadsheet. Please help. Thank you. |
[2019-12-12 16:15:28] |
This is not documented and is well outside the scope of our support to help with this and would be a major major task. We simply cannot commit any time to this. Accept it is not usable.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-12 16:16:07
[2019-12-12 16:19:39] |
Can you please tell me the size of the header in bytes for the .scss file. I will figure out the rest.
