Date/Time: Sat, 27 Apr 2024 19:36:45 +0000
Write Data to File data missing
View Count: 505
[2019-12-12 02:15:01] |
User162532 - Posts: 4 |
Hi, the file will failed to update if there is over 999 (the maximum millisecond count)records for the tick data posted in the same second. Are there any method to avoid this?
[2019-12-12 22:53:15] |
How do you come to this conclusion? This is definitely not an issue.
