Date/Time: Sat, 04 May 2024 16:57:33 +0000
Data integrity
View Count: 670
[2019-12-10 18:05:28] |
User871277 - Posts: 34 |
I can't really expalain how that may happen. Same symbol, two instances, different data. Makes me wonder about reliability of the SC Data feed. Also SCH seems to completly ignore the "days to load setting". Maybe it is me, but I don't manage to get more than 30 days. @Support, sorry, I just learned about the screenshot policy. I removed Datafile so atm I am not able to reproduce the situation. |
Attachment Deleted. Stranger-Things.png / V - Attached On 2019-12-10 18:03:38 UTC - Size: 405.87 KB - 230 views |
[2019-12-13 23:46:19] |
I assume it happened cause my computer was in hybernation. But still isn't Sierra supposed to check and verify? If timestamps do not match, trigger historical download? |
[2019-12-13 23:52:10] |
Those are Renko bars. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration To chart more than 30 days, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data If there is missing data, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-14 13:33:27] |
Still the question of hybernation stays...
