Date/Time: Tue, 30 Apr 2024 20:54:27 +0000
Remove Trade Window Control buttons
View Count: 978
[2019-12-10 15:11:39] |
gmorgan111 - Posts: 121 |
I have been trying to remove a couple of trade window buttons. I have only been able to find how to enable or disable the buttons by ask buy bid and so on but I have been unable to find out how to remove them completely. Can you show me how to remove them from the window Thanks George |
[2019-12-10 18:12:15] |
The buttons cannot be removed, they can only be turned off, as you have already found.
[2022-03-29 13:30:20] |
User177741 - Posts: 41 |
Hiding buttons would be a great feature. I would second this.
[2024-02-04 03:51:49] |
A Leo - Posts: 4 |
+1 for hiding trade window buttons. This would be a great feature. It's probable many traders find the buy ask/bid and sell ask/bid extraneous and would respond to tightening up the trade window with the feature to remove these; similarly, those that do not execute at market may benefit from hiding their mkt buttons to have only the others in focus. Thank you! |
[2024-02-04 05:18:29] |
User83524 - Posts: 27 |
Definitely, I would agree! Hide the extra buttons.
[2024-03-05 11:53:59] |
User835799 - Posts: 4 |
+1
