Date/Time: Tue, 07 May 2024 20:27:52 +0000
KB Shortcut or Control Bar Button for Scale In and Scale Out Type
View Count: 976
[2019-12-10 12:39:41] |
ARDAN - Posts: 66 |
Under General Trade Settings> Scale-In and Scale-Out fields has two options. nearest and furthest. Is there a way to change these settings via a keyboard shortcut or preferably Control Bar button? Thanks. |
[2019-12-12 12:45:56] |
ARDAN - Posts: 66 |
Reminder, thanks.
[2019-12-13 18:36:20] |
ARDAN - Posts: 66 |
it looks like you don't give support for paid users as well. What I am asking is not defined in the documentation so where should I consult?
[2019-12-13 19:04:08] |
No that is not the case. It is just that some requests take us more time to get to. There is no way to change these by keyboard or control bar button.
