Date/Time: Thu, 02 May 2024 17:58:33 +0000
Version 1941
View Count: 650
[2019-12-09 23:27:05] |
John - SC Support - Posts: 31324 |
Where is that information being generated from? Is that a custom DLL study that you created or was created for you? If it is a DLL provided to you, then you would need to upgrade to see if it will still work and whether it will work with CQG data. If there is a problem, then you would need to contact the developer of the program to fix it. Most often, it is just a matter of needing a recompile for the most recent version of Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-10 13:42:00
[2019-12-10 13:45:37] |
You need to run the current version of Sierra Chart to connect to CQG. Update instructions: Software Download: Fast Update So you want to display the total volume of a TPO profile directly on the TPO profile? If so, refer to this Input and the next three: Time Price Opportunity (TPO) Profile Charts: Show Chart Values On Profile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-10 13:46:51
