Date/Time: Sat, 27 Apr 2024 17:27:26 +0000
[User Discussion] - Looking for a particular study (or something similar)
View Count: 623
[2019-12-09 21:59:46] |
samuelson - Posts: 9 |
I am looking for a study that shows the number of candles that don't have wicks on the color side of the candle, over a number of candles (eg. past 30 candles) using the chart timeframe. See example drawing attached. Or if there's already a study that's similar or at least to this effect. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=33660 |
Screen Shot 2019-12-09 at 16.40.43.png / V - Attached On 2019-12-09 21:58:40 UTC - Size: 20.99 KB - 318 views |
[2019-12-09 22:56:13] |
There may be a study like this in the User Contributed list of studies. Look and see if you can find something in there. Refer to the following: Chart Studies: Adding/Modifying Chart Studies Otherwise, this would be something you could develop using the Spreadsheet Study. Refer to the following: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-09 22:59:48] |
Ackin - Posts: 1865 |
Hi, you can download it as a finished study Study: "Count No-wick bar" contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:48:12
[2019-12-09 23:11:44] |
Ackin this is awesome! Thanks.
[2019-12-09 23:24:46] |
Check your email, read the registration message with instruction and enjoy more than 150 free studies ;)
