Date/Time: Fri, 03 May 2024 21:44:01 +0000
Initiate Trail while in Position?
View Count: 568
[2019-12-09 17:13:19] |
ycomp - Posts: 274 |
I'm guessing there's no way to do this but I thought I'd ask to find out for sure... Once I enter and the attached orders execute, (e.g. take profit and stop order bracket) is there a way to convert the stop order to a trailing one by custom keyboard shortcut or context menu or somehow? I mean I know you can set it up to be a trailing stop from the get-go but I'm thinking if you're manually trading and decide you want to start trailing |
[2019-12-09 18:20:23] |
John - SC Support - Posts: 31362 |
You would have to close out the previous Stop and then you can attach a new Stop order using the Trading Order type of Send Attached Orders. Refer to the following: Order Types: Send Attached Orders - Position/Price For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-11 03:03:00] |
More information: Attached Orders: Changing Attached Orders Configuration After Parent Order Has Filled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
