Date/Time: Thu, 02 May 2024 08:12:15 +0000
Upstream: Bug in NotePad++ causes file to be overwritten with empty file
View Count: 1109
[2019-12-08 11:48:49] |
T44 - Posts: 363 |
I've just run into this bug. https://github.com/notepad-plus-plus/notepad-plus-plus/issues/3253 As you bundle NPP can you please distribute a version >= 7.6.6 which fixes this? Thanks (I only lost an hour or so of unstaged changes as I keep SierraChart install directory under git) Date Time Of Last Edit: 2019-12-08 12:00:06
[2019-12-10 18:14:49] |
We will update the Notepad++ editor.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-10 18:14:58
