Date/Time: Sat, 04 May 2024 10:13:56 +0000
GDI function access to SC
View Count: 1371
[2019-12-07 11:41:04] |
jesslinn - Posts: 108 |
The "Custom Free Form Drawing into Chart Window Using GDI" documentation section says that the drawing function has complete access to the ASCILL sc structure but that it is read-only. There does appear to be access to the variable members but the functions do not appear to work. For example, the function sc.GetChartBaseData gets data from another chart perfectly in the scsf function call but receives 0 size arrays if called from the draw function. Is this by design? What are the limits to what one can do with the restricted sc structure? Date Time Of Last Edit: 2019-12-07 18:04:33
[2019-12-08 04:45:55] |
No that is not by design. This will be resolved in the next release.
