Date/Time: Fri, 03 May 2024 07:58:48 +0000
FX decimalization
View Count: 534
[2019-12-06 14:06:38] |
EuropeanTrader - Posts: 290 |
Hi, when using FXCM SC ALL data services for FX products, how can I enable that the chart automatically displays 1/10th of a pip (0,00001) and not halfs (0,00005) for all symbols at once? Is there a way so that I don't change each symbol individually in the Symbol settings? Thank you! |
[2019-12-07 04:48:37] |
You do have to manually change the Symbol Settings for each symbol and after update any charts for those symbols.: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-07 07:07:57
