Date/Time: Wed, 08 May 2024 16:50:25 +0000
Daily close price plotted as points
View Count: 705
[2019-12-06 09:40:33] |
grantx - Posts: 244 |
Is there a way to plot price movement as a series of points on the chart? Basically I would like to look at the daily chart and only see the closing price for each day. I have attached a sample of what I mean. Each point represents the closing price of oil over the last x amount of days. Thanks. |
[2019-12-06 10:22:25] |
User907968 - Posts: 802 |
One way you could do it: - Set 'Graph Draw Type' to 'Blank' Chart Settings: Graph Draw Type (Chart >> Chart Settings >> Bar Period >> Graph Draw Type menu) Graph Draw Types: Introduction - Apply 'Daily OHLC' study to chart, set 'Open', 'High' & 'Low' subgraph drawstyles to ignore and then set an appropriate drawstyle for close Daily OHLC No doubt there is a better way than this, but it works. |
points on close.png / V - Attached On 2019-12-06 10:22:12 UTC - Size: 24.82 KB - 245 views |
[2019-12-06 11:14:01] |
Works perfectly! Thank you.
