Date/Time: Sat, 04 May 2024 03:40:51 +0000
Fees
View Count: 572
[2019-12-06 03:46:40] |
ITBFG - Posts: 5 |
I would like to be able to have 3 additional people to be able to login to my account and use the live charts and data when activated...how much will that cost?
[2019-12-06 17:47:28] |
You can have Sierra Chart running on 2 computers at the same time. To have additional systems at the same time, it is an additional $12 USD per month per system. You can add the additional systems on this page (towards the bottom under Additional Systems): https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation But, you may run into limitations with the data. The CME limits the number of simultaneous connections to 2 per account for live data. If you are interested in the data from Sierra Chart, then refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart Sierra Chart does have Delayed Streaming Data available for the CME Group if you are on Package 5. This does not have any limitations to the number of connections. Refer to the following to see if this may work for your needs: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
