Date/Time: Sun, 28 Apr 2024 11:04:57 +0000
SC with Denali...Where to a get my AD Line?
View Count: 969
[2019-12-06 01:38:53] |
Joseph Helminiak - Posts: 21 |
Okay, So I am on the Sierra Chart bandwagon now 🙂 Dumping my IQ_Feed sub the end of this month (had yearly sub) and starting Denali CME feed. Where do I get things like tick, AD Line / net issues? My costs are dropping from about $250 per month to less then $100 (which I'm happy about) |
[2019-12-06 11:20:33] |
User390455 - Posts: 56 |
If your search Advance Decline Line : Advance Decline Line |
[2019-12-06 16:16:33] |
Okay I'm not 100% but I think I need to run two instances of SC, One for each data source. When I follow this: https://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php#top Then I dont get my IQ_Feed data |
[2019-12-06 16:34:00] |
Sierra_Chart Engineering - Posts: 14111 |
Where do I get things like tick, AD Line / net issues? These are part of the Sierra Chart market statistics. Here is the documentation which you have already seen:Sierra Chart Market Statistics You do not need to run two separate instances of Sierra Chart. The market statistics are accessible with all of the supported Data and Trading services. You will find the symbols in File >> Find Symbol >> Market Stats. Let us know if you need more help. Regarding real-time data from exchanges, what exchanges did you need data for? We can help you get set up with the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-06 16:34:37
[2019-12-06 17:01:19] |
I attached a file showing that I don't have the "market stats" dropdown item. This is why I thought I may need to run another copy
SC Data.jpg / V - Attached On 2019-12-06 16:51:57 UTC - Size: 123.07 KB - 272 views Attachment Deleted. |
[2019-12-06 17:25:22] |
This is because you are still using IQ Feed. So these Sierra Chart market stats are not listed when using IQ Feed so you do not get confused between our statistics and IQ market statistics. In this particular case you can install another copy of Sierra Chart and access the SC market stats that way. Refer to: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-06 22:56:52
[2020-01-12 17:46:20] |
grayfrog - Posts: 35 |
To clarify this point. While using any SC service package, you get SC real-time Market Statistics. This is regardless of whether your real time data feed is Denali or SC real-time exchange data. Question: - If Sierra Charts data/trade service setting is set to "SC Futures Order Routing/Data", does that have any bearing on receiving real time Market Statistics? - Does having "SC Futures Order Routing/Data" selected affect receiving real time Market Statistics quotes on the QuoteBoard? Attached is a screenshot as the basis of my question. Are the Market Statistics not showing up on the QuoteBoard because the market is closed right now? For reference, I can pull up the intraday and historical charts for these statistics. Thank you. |
2020-01-12_09-40-47.png / V - Attached On 2020-01-12 17:43:49 UTC - Size: 246.53 KB - 266 views |
[2020-01-12 19:01:03] |
- If Sierra Charts data/trade service setting is set to "SC Futures Order Routing/Data", does that have any bearing on receiving real time Market Statistics? No.Are the Market Statistics not showing up on the QuoteBoard because the market is closed right now? Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-12 19:01:08
