Date/Time: Mon, 06 May 2024 05:36:07 +0000
Creating Own study from study collection
View Count: 1089
[2019-12-05 13:21:29] |
User33743 - Posts: 83 |
Hello, Is this possible to create one study from study collection? What i want to achieve: I have a package of 6 indicators in study collection but i don't want them to be changed by anyone hwo will be using it. Is this possible to "compile" them together? Best Regards |
[2019-12-05 14:30:59] |
No but you can certainly password protect them which can prevent changes: Chart Studies: Password Protecting Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-05 14:31:24
[2020-01-14 13:48:32] |
Is this possible to change the name of study? e.g Moving average Simple into something different "XXXX" ? Or maybe i can copy this study and change name? Where i can find default studies? Best Regards |
[2020-01-14 14:57:26] |
Ackin - Posts: 1865 |
How to Build an Advanced Custom Study from Source Code: Introduction The study functions for the built-in studies can be found in the studies#.cpp files in the /ACS_Source folder in the folder Sierra Chart is installed to on your system.
[2020-01-14 19:00:54] |
You have to take the source code for the study and change the name and then recompile it. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-14 19:00:59
