Date/Time: Thu, 02 May 2024 00:50:50 +0000
Sierra Chart Daten broker
View Count: 607
[2019-12-04 16:49:38] |
Torsten Grüß - Posts: 45 |
it is possible to trade through IB and get data from Rithmic so a separation of data and broker |
[2019-12-05 14:50:54] |
Sierra Chart has discontinued technical support for Rithmic. And there is a far far better solution. What you will want to do instead is use this service with Interactive Brokers: Denali Exchange Data Feed Also refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-05 14:51:07
