Date/Time: Sat, 04 May 2024 11:08:15 +0000
Short trading days
View Count: 627
[2019-12-04 15:53:47] |
User753843 - Posts: 8 |
Hello, I'm using some OHLC studies that use RTH hours only, which end at 4pm EST. However, for Thanksgiving (and other holidays), RTH ends at 1pm and skews the data on my studies. The OHLC studies end up using ETH data on shortened days. Is there any way to manually change the RTH hours for specific days, or to prevent studies from using ETH hours data on shortened days? Thank you! |
[2019-12-05 04:03:04] |
Refer to this particular setting: Chart Settings: Set Dates To Exclude (Button) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Some studies like the Relative Volume study can be set to skip over days where there is insufficient trading activity due to holiday trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-05 04:05:13
[2019-12-05 04:24:58] |
Thank you. I'd like to include RTH data for the shortened day, just exclude ETH. Is this possible?
[2019-12-27 21:07:04] |
Chad - Posts: 231 |
up - I'm interested as well.
