Date/Time: Fri, 03 May 2024 09:22:36 +0000
Connection error message
View Count: 546
[2019-12-04 13:33:36] |
User904499 - Posts: 1 |
I have have problem logging in Sierra Chart. TransAct Trading logon error received from server. Disabled API Token I have added credit to my account. please help
[2019-12-04 15:23:10] |
Transact has locked out the old Transact bridge program. So you need to update to the current version of Sierra Chart to be able to connect to Transact: Software Download: Fast Update After updating you most likely will get an Account Logon Error. In this case, refer to: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
