Date/Time: Sun, 28 Apr 2024 18:51:27 +0000
Fixed angle for rays is inaccurate
View Count: 613
[2019-12-04 09:54:19] |
grantx - Posts: 244 |
When I modify the angle of a ray, the angle is not represented properly. See attached. The 90 degree setting works. The 0 degree setting works. The 45 degree setting is completely wrong. Do you have some kind of protractor overlay tool or something? I would like to see the angle of certain swings. Thanks. |
[2019-12-04 11:01:43] |
User907968 - Posts: 802 |
Did you read this, it might help you out? Chart Drawing Tools: Drawing a Line with a Specific Angle or Slope |
[2019-12-04 22:06:11] |
Yes this is the relevant documentation to refer to: Chart Drawing Tools: Drawing a Line with a Specific Angle or Slope Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
