Date/Time: Mon, 06 May 2024 19:39:00 +0000
Exchange: TURK
View Count: 897
[2019-12-03 19:18:37] |
ARDAN - Posts: 66 |
How can I chart and trade these symbols? Exchange: TURK https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#TURK |
[2019-12-04 15:54:00] |
The Sierra Chart Historical Data service only has support for Historical Daily data for those particular symbols. If Interactive Brokers has Real-Time data available for that exchange, then you can use Sierra Chart with Interactive Brokers. If they do have it, then refer to the specific link in the following page for that service: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-04 15:55:08
[2019-12-09 20:06:43] |
ARDAN - Posts: 66 |
How can I enable them to chart?
[2019-12-10 21:47:12] |
From what data feed/service?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-10 21:47:20
[2019-12-11 06:05:08] |
ARDAN - Posts: 66 |
You said "The Sierra Chart Historical Data service only has support for Historical Daily data for those particular symbols." so via this. |
[2019-12-12 12:45:49] |
ARDAN - Posts: 66 |
Reminder, thanks.
[2019-12-13 18:36:09] |
ARDAN - Posts: 66 |
it looks like you don't give support for paid users as well. What I am asking is not defined in the documentation so where should I consult?
[2019-12-14 06:28:08] |
We need time to go over the Symbol Settings for these. This is the reason for the delay.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-14 06:28:20
[2019-12-17 05:20:16] |
We are setting up the symbol settings fully for these TURK symbols and it will be done later in the day today.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-17 05:20:36
[2019-12-17 13:44:34] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-05 18:21:07] |
kasabo - Posts: 27 |
Sorry but I could not find these symbols after updating my symbol settings. What am I missing? |
Capture.PNG / V - Attached On 2020-01-05 18:20:30 UTC - Size: 14.97 KB - 239 views |
[2020-01-05 23:05:26] |
Are you using LMAX?
[2020-01-17 09:04:41] |
Yes
[2020-01-18 08:34:07] |
[2020-01-23 12:05:44] |
I am getting a symbol service code not specified error.
[2020-01-23 23:55:51] |
Sierra_Chart Engineering - Posts: 14244 |
This is now resolved. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-23 23:56:02
