Date/Time: Sun, 05 May 2024 02:40:45 +0000
slow charts
View Count: 1190
[2019-12-02 21:25:05] |
User143551 - Posts: 96 |
infinity transact futures charts are still slow they have been slow over a year when the volume goes up a little the charts slow or stop EVERY DAY, I have told sierra about this several times ,that makes sierra look bad they blame sierra and making us keep changing the charts we are at 2017 now and it dose not work when a little vol comes ,the es is off several times a day over 12 ticks, dome works good charts suck ,I have been trading 15 yrs can some do smoothing I have done all I can I have contacted transact several times and infinity I am not the only one saying this there are several other traders SIERRA SHOULD DO SMOTHING BEFOR WE ALL QUIT kent Henderson 423 764 2005
[2019-12-02 23:59:47] |
There are other supported services you can work with and they are documented here: Supported Data and Trading Services You can make a decision to use another supported service that we work with. We have written this section about this issue: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SolvingLaggingDataFeed_StoppingDataFeed_MissingDataIssues The very best-performing data feed is going to be this data feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-03 00:01:24
[2019-12-03 02:04:52] |
I need someone to talk on the phone about denalie feed I have no idea what to do to keep my charts and switch over from transact to denalie and other things to get this going thanks kent Henderson 423 764 2005
[2019-12-03 05:25:11] |
We will contact you.
[2019-12-03 14:54:18] |
SC Support - Posts: 1797 |
Spoke to Kent, working through his issues with him.
[2019-12-12 16:45:59] |
send me a e mail or call kent henderson
[2019-12-12 19:26:12] |
spoke to Kent, working through his issues
