Date/Time: Thu, 02 May 2024 11:13:07 +0000
CHART DOM No modification available
View Count: 583
[2019-12-01 00:25:31] |
User659208 - Posts: 22 |
Hello, My chart DOM does not show any level where I could modify. I could only modify my order through the chart level. Will there be any way to activate the modification on chart DOM? |
[2019-12-01 00:50:03] |
Follow the instructions on this page: Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-01 01:25:18] |
I couldnt find the information. Here is an example of what I mean... If you look at the picture, you wont see any working orders on the Chart DOM.
Orders.PNG / V - Attached On 2019-12-01 01:24:25 UTC - Size: 75.07 KB - 275 views |
[2019-12-03 00:30:29] |
Ok that is because the market depth is displayed in those columns. You need to change those columns to not have market depth data: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-06 15:40:25] |
In this case, which data should I remove to show the modification? I attached another example. I have the Recent Bid/Ask in this DOM but the modification is still there.. However, this is a trade DOM not chart DOM. Not sure if that affects.
Orders.PNG / V - Attached On 2019-12-06 15:39:29 UTC - Size: 50.77 KB - 244 views |
[2019-12-06 15:49:46] |
Still does not show up after I remove on the chart DOM..
Orders.PNG / V - Attached On 2019-12-06 15:49:27 UTC - Size: 121.08 KB - 242 views |
[2019-12-08 04:29:57] |
Refer to the Buy and Sell Order Column descriptions here: Global Trade Settings Windows: Chart/Trade DOM Column Descriptions You need to add these columns. This is what you want and the documentation explains this. You will then have to add separate market depth Quantity columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-08 04:31:35
