Date/Time: Sun, 05 May 2024 11:54:03 +0000
2 Accounts with sierra
View Count: 831
[2019-11-27 09:57:43] |
User912405 - Posts: 14 |
I want to work over Sierra in 2 accounts: - AMP - Dorman For this I would like to use the data-feed from Sierra. As far as I know so far, I always get the data via my broker, where I pay for the data. If I work with 2 accounts, I would have to pay 2 times for the same data feed. What do I have to do, so that the costs only arise once? |
[2019-11-27 11:35:14] |
What markets do you need data for or want to trade? For example, what particular futures symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-27 11:35:39
[2019-11-27 13:06:01] |
I trade only MNQ and NQ But my question was whether I could trade with the Sierra data feed over 2 accounts / brokers without having to pay 2 times. Date Time Of Last Edit: 2019-11-27 13:06:20
[2019-11-28 06:20:31] |
Yes you most definitely can do this. This is supported with the Sierra Chart data feeds. This is the one you will want to use: Denali Exchange Data Feed You can use this with two installations of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-09 22:29:52] |
what exactly do I have to do to start the data feed from denali on 1.1.2020? (please step for step) I want to trade NQ and ES with market depth, no further symbols I have an account with: - AMP - Dorman |
[2019-12-09 23:19:12] |
John - SC Support - Posts: 31362 |
First, if you have not already done it, you would need to install 2 different installations of Sierra Chart. One that will be used with AMP and the other that will be used with Dorman. The specific setup instructions will depend on what trading service is being used by the broker. You will login to both installations using the same Sierra Chart username and password. In order to get the Denali Exchange Data Feed functioning, just follow these instructions on January 1, 2020: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* You would just need to repeat this section of the instructions for each installation: Denali Exchange Data Feed: *Setup Instructions: Sierra Chart Software Instructions* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-17 18:12:36] |
Would it be possible for me to get a test access for 14 days first, which then automatically changes to pay?
[2019-12-17 19:08:43] |
Next week we will be rolling out the first month of the Denali Exchange Data Feed for free for the first month. As long as you have not previously used your account with the CME Group, you would get both the data feed and the exchange for free. Please wait for another week and check back with us to see if this has been completed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-26 10:33:18] |
are the credentials for -- Denali 1 Month free-- are available?
[2019-12-26 14:10:55] |
The Denali Exchange Data Feed is free until the end of the first month. This is available now. Instructions are on this page: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-26 14:11:41
