Date/Time: Fri, 19 Apr 2024 21:09:32 +0000
Importing large tick data file
View Count: 562
[2019-11-26 16:24:07] |
pa_trader - Posts: 29 |
I'm tyring to import a large file (~33GB) and I'm not sure if SC is processing or is there some kind of error. I've checked a section of this file and I can confirm the formatting etc works. Is it simply a matter of the size ? Please see attached, thx |
TickDataImport.png / V - Attached On 2019-11-26 16:23:47 UTC - Size: 57.01 KB - 264 views |
[2019-11-26 22:17:27] |
In that log that you posted an image of there is a temporary file name that you highlighted. Periodically check that file size to see if it is growing during the Import. If it is, then Sierra Chart is continuing to do the import. We would not expect anything to go wrong.
[2019-11-27 01:04:24] |
dont think its growing, an hour later its still at 1KB
[2019-11-27 02:12:03] |
confirming its not growing at all. Still at 1KB after 2 hours and no new messages on Message Log window thx |
[2019-11-27 03:18:31] |
Can you compress the file with 7Z and attach it here and we will test.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-27 03:18:43
[2019-11-27 13:53:39] |
Looks like the import did work. I left it running on my work PC before leaving yesterday and this morning it looks like it finished in about 5 hours !! One problem I did face was that my tick data finished mid-day 11-Nov-19 but then SC downloaded and appended to the file the data for stock "ES" (my file was called ES.scid). Is there any way to stop it from doing that. thanks for looking into this, but this may have been a false alarm... |
[2019-12-03 05:04:34] |
You could set the Service in Sierra Chart to "No Service" to avoid this.
