Date/Time: Tue, 04 Nov 2025 14:57:38 +0000
No $TICK data coming in
View Count: 3247
|   [2013-03-21 16:43:32]     |
| joshtrader - Posts: 526 |
                As of about 30 minutes ago, I stopped receiving NYSE $TICK data.  It was coming in fine until then.  Tried with two separate copies of SC, with a different data provider connected on each one.  This chart downloaded all the back data and so the historical data also looks this way for sure. http://www.sierrachart.com/image.php?l=1363884081957.png  |
|   [2013-03-21 16:45:02]     |
| M5amhan - Posts: 468 |
                im having the same problem here.. also the $NSHF advance decline line has stopped working as well
|   [2013-03-21 16:56:38]     |
                We know.  We have contacted our data provider.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
