Date/Time: Mon, 03 Feb 2025 12:50:57 +0000
CQG Micro Nasdaq incorrect price
View Count: 577
[2019-11-19 16:09:42] |
User145424 - Posts: 11 |
Hi, The pricing of the Micro Nasdaq shows as 33280 and similar whereas the price on the CQG platform shows as 8321, which is correct. Therefore, trading the micro is not possible as I have no idea what value is related to what price. Is there some setting that needs changing to make this work properly? S+P, Dow and Russell seem fine. |
[2019-11-19 16:34:04] |
This is a CQG server issue that occurs sometimes related to incorrect metadata. We recommend using this data feed instead: Denali Exchange Data Feed For the time being to solve the problem you need to reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers And then you need to re-download the data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-19 16:34:16
