Date/Time: Wed, 01 May 2024 23:56:21 +0000
Average price problem
View Count: 578
[2019-11-14 18:02:30] |
User45038 - Posts: 10 |
Hello, I am in live positon with 3 contract MICRO EURUSD. The problem is that the trade position window calculates wrongly with the average entry price. I opened each contracts at different prices but the trade position window "put" the whole position at the last opened contract price. The first and the second short were opoened 2 days ago at higher price. What may be the problem? The chart trade position line shows the price correctly. Thank you! |
Private File |
[2019-11-15 05:41:09] |
Refer to the documentation here: Trading Information Windows: How Average Price for Positions Is Calculated and Used This can be related to missing order fills, in which case you should use this service to avoid that: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-15 05:41:38
[2019-11-15 05:42:35] |
Another thing to check is to make sure the chart is loading order fills at least as far back as the start of the position: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
