Date/Time: Sat, 12 Jul 2025 06:18:59 +0000
Volume by price DOM study text size
View Count: 1890
[2019-11-14 17:43:01] |
BenjFlame - Posts: 338 |
Hello, on a DOM I added volume by price study and I set it to display volume numbers. However the text is too big and I would like to know how to control its size. I was thinking the "font size" setting of the study would do it but it does not as you can see on image. Where is the setting then? |
[2019-11-15 05:43:09] |
That particular text is controlled by the Subgraph named Volume Numbers Text Color and Size. You will find the information about this here: Volume By Price Study: Volume Numbers Text Color and Size (SG7) The Text Font Size that you are seeing is for the values that are displayed above and below the Volume Profile. You will find the information for that Input here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#TextFontSize Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
