Date/Time: Fri, 03 May 2024 07:56:04 +0000
HAS UAS Need Modifying
View Count: 702
[2019-11-14 13:29:42] |
User821468 - Posts: 84 |
Suggest UAS in Particular needs modifying in that it not only unhides the studies of the momentarily hiden studies by HAS, but also all the studies previously hidden by the Hide check marks in the study windows.These previously and purposely hidden for one reason or other ought not be unhidden by the UAS button at least IMHO. Thank you At least perhaps an option to include/exclude prior hiden studies should be included in/with UAS. Date Time Of Last Edit: 2019-11-15 16:30:16
[2019-11-17 13:02:51] |
Is my suggestion valid? Thanks
[2019-11-25 15:02:04] |
Further to my prior comments on the matter, I noticed, after implementing a UAS command, the body shape of the prior 5-10 candle seem to follow the current candle fluctiations. Cant figure that one out, Thanks
[2019-11-25 15:18:03] |
In regards to post #1 we understand. We will see how to implement support for this. In regards to post #3, we are not understanding this. A problem like this does not make sense to us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-25 15:22:25
[2019-11-25 21:02:07] |
How can I send you a screen shot of my chart with HAS and UHS. Thanks
[2019-11-28 04:02:47] |
Update Sierra Chart to the current version for the updated functionality regarding hiding and unhiding studies: Software Download: Fast Update Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-24 20:00:45] |
Suggestion: It is suggested that HAS and Uah refer only to the studies presently active on the chart, and not all studies in the study panel, This will answer my earlier post about HAS deleting all studies.Thank you |
[2020-01-27 18:38:30] |
Sierra_Chart Engineering - Posts: 14189 |
Yes, this has already been implemented as long as you are running a current version of Sierra Chart.
